スタックシーケンスストラクチャについて
初歩的な内容になるかもしれませんが、スタックシーケンスストラクチャでセレクトラベルの数値が黒塗りになっております。
これはどのような意味を持っているのでしょうか?
(225 Views)
looks like a graphics glitch that does not cause problems What version of LabVIEW is this? What is the OS?
(It should also not really matter, because nobody should use stacked sequences anymore. They have been removed from the palette for that reason)
(202 Views)
Accepted by topic author Sword-Three
I experienced this a lot of times with different LV versions. As Altenbach states, this couses no proplems and disappears after a while. This means, after some days, while editing the VI and with several save-sycles. But I didn't find a deterministic rule for the disappearance.
Greets, Dave
(193 Views)
The OS is Windows 11.
LabVIEW is 2020.
(164 Views)
Thank you very much.
(158 Views)
