BUG: Path abbreviation behaviour
If the filename don't fit into the Path control the abbreviation cuts out all and shows nothing. It should show something, right? Like "...\...-d21e141c5ce2_1.pdf"
LV2019, LV2024
Qestit Systems
Certified-LabVIEW-Developer
Message 1 of 11
(3,367 Views)
You can set it to Clip path, to display partial path.
Mano Prabha
Message 2 of 11
(3,340 Views)
Yes, but then i only see the beginning part of the path, i want to see as much of the file name as possible. "C:\user\Documents" doesn't tell me much. 🙂
Qestit Systems
Message 3 of 11
(3,304 Views)
Hi Yamaeda,
So the described behaviour is not a bug, but "just unwanted/unexpected" because you want a "different behaviour"?
Workarounds:
  • Put the whole path into the tipstrip of the path control: now you could read the whole path when you hover the mouse of the control…
  • Enlarge the control…
Message 4 of 11
(3,301 Views)
Another try:
1. If you want to keep the appearance of the path control (path glyph) place a transparent string control on top of the path control. The path control gets the font color to white.
2. The string control needs to be set to "Limit to single Line" and unchecked at "Enable Wrapping", the "Text Overflow" setting needs to be unchecked, the text alignment needs to be set to "right"
3. In the "Value Canged"- event of the path control the value of the string control gets updated.
Another advantage of this is, that even too long filenames for the control will be shown with as many letters as possible.
Greets, Dave
Message 5 of 11
(3,273 Views)
@GerdW wrote:
Hi Yamaeda,
Workarounds:
Abbreviation - Wikipedia
We can ofc show nothing in the control, that'd be the strongest abbreviation ...
Qestit Systems
Message 6 of 11
(3,218 Views)
I don't know if this a bug, but maybe a lack of rules.
If you ever read about TeX, you would know there are all sorts of typesetting rules as far a spacing goes or extending into the margins, where to put a break, etc. It's why a TeX document looks and reads so much better than a similar Word document.
My guess is there are simple rules for the path control as to where to abbreviate, and if none of those rules can be applied, then it defaults to the dots you see. I also guess that some of the rules are probably hidden property nodes or special ini file settings. Maybe NI can release them so we can modify the rules to our liking.
Message 7 of 11
(3,186 Views)
That would ofc help a lot, though i would assume it'd show as much as possible in the available indicator as standard.
Qestit Systems
Message 8 of 11
(3,137 Views)
Did anybody suggest this as a LabVIEW Idea? Could be worth it.
Greets, Dave
Message 9 of 11
(3,077 Views)
sometimes, the abbrevation is as yamaeda expected it to be, when the width of the path control or indicator is "right":
Message 10 of 11
(3,060 Views)
