使用LabVIEW 2017版本加载基于.NET生成的DLL时,报告1589错误
使用LabVIEW 2017版本加载基于.NET生成的DLL时,报告1589错误:
Error 1589 occurred at Constructor Node loading the assembly from path ...\MeFunctionDll.dll in ME LOGIN.vi
Possible reason(s):
LabVIEW: (Hex 0x635) The loaded .NET assembly was not found in its original directory.
(1,296 Views)
@weller321 wrote:
When loading a .NET-generated DLL using LabVIEW 2017, a 1589 error is reported: Error 1589 occurred at Constructor Node loading the assembly from path ...\MeFunctionDll.dll in ME LOGIN.vi Possible reason(s): LabVIEW: (Hex 0x635) The loaded .NET assembly was not found in its original directory.
These links might be helpful
Error Loading .NET Assemblies in LabVIEW
How LabVIEW Locates .NET Assemblies
https://tmesystems.net/
(1,260 Views)
