Dependency Loaded from New Path
I realize similar issues have been addressed on this forum before (which I've reviewed and attempt to look at documentation), but I'm having trouble with the above error occurring when I attempt to open an analysis program for LabView. I recently got a new computer and downloaded LabView onto it, and when I attempt to run the program pictured (which is available to open from the LabView 2020 initial screen) I get the the errors pictured in the PPT. For each time that the search dialogue pops up for each of the noted VIs, I select the same program (SNR Final Agilent E490 updated) and click OK. This happens for a total of 6 different VIs, though only a single warning is noted.
The program seems to open, but I have yet to attempt to run it and I am worried about the integrity of any information gathered if things are amiss. I am unable to find specific VIs by the names of those requested (ie. Configure Aperture.vi, Configure Measurement Signal.vi, etc) in either the expected or specified folders, so am uncertain how to resolve the issue. There was also mention in previous posts of documentation that would help with this, but I trouble tracking down exactly which documentation was relevant.
Any help would be greatly appreciated.
Thank you
(1,526 Views)
That's a missing instrument driver.  NI has a place to download those here:
https://www.ni.com/en/support/downloads/instrument-drivers.html
This is probably the one you want:
https://sine.ni.com/apps/utf8/niid_web_display.download_page?p_id_guid=2DDE691A01153D65E0440003BA7CC...
Since you use 2020, get the 2018 one, unzip it, and put it in the location in the 2020 folder that matches the path shown in the popups you get.
(1,495 Views)
Awesome, thank you for the help. I've downloaded the driver, but will need to wait until I have access to the instrument again to confirm it works.
(1,442 Views)
