在LabVIEW8.6环境下,请问如何能根据程序不同的运行结果动态创建显示控件
程序主要完成的功能是搜索Excel表格中相匹配的内容并显示在表格控件中,每条结果占用表格控件的一行,前面都简单,如果产生n条结果,即动态产生n个选择控件分别与n个结果相关联,请问各位大哥怎么实现,我是新手,感谢您的回复,谢谢!
(2,740 Views)
English version:
LabVIEW8.6 in the environment, but how can the different procedures based on the results show that the creation of dynamic control
The main program to complete the search function in Excel spreadsheet to match the content displayed on the form and control, the results of each table occupied by his party's control, all in front of a simple, if n produce results, which have a dynamic n control option with n The results were associated with, I would like to ask you to realize how big brother, I am a novice, thank you for your reply, thank you!
(2,726 Views)
NI应用工程师:可以动态的显示和隐藏数字显示控件,并且可以通过数字显示控件的属性节点来改变每个数值的显示效果。
(2,694 Views)
