Help needed on TCP/IP Multi-port Client-Server
Hi all, I am trying to develop a client-server application to stream some data over a few random port numbers (defined by myself) to stream data over to the TCP server (i.e another computer) in LabVIEW. So far, I have created my application using the NI examples for "Simple Data Client + Server" and it works fine. I also understand that the "TCP Listen" VI is only able to listen for 1 TCP connection only and a way around this is to use queueing idea to receive & process the incoming data.The downside to the idea is that the "base port" (i.e initial port) needs to be the same (on every TCP client) with the TCP Server and it is not fit for the purpose I intended.
Basically on the TCP server side, i need to chart/monitor the data on different port numbers that is being streamed real-time from the one TCP client computer. Is this possible in LabVIEW?
Can anyone (incl. NI gurus) advise and point me in the right direction?
*lost*
Message 1 of 8
(6,897 Views)
             It is possible to view/monitor the data and also you can transfer the data to Host PC through TCP using Functional Global.
https://www.ni.com/en/support/documentation/supplemental/21/command-based-communication-design-patte...
https://www.ni.com/en/support/documentation/supplemental/21/simple-messaging-stm-communication-libra.... Hope this helps you.
Message 2 of 8
(6,894 Views)
Thanks...By any chance do you know where is it possible to obtain a ready example VI regarding the STM? Suggestions are welcome.
Message 3 of 8
(6,889 Views)
Accepted by topic author kilo5k
Hi
    https://www.ni.com/en/support/documentation/supplemental/21/simple-messaging-stm-communication-libra... Here you can download that component.But you can also use TCP icons which is available in Data Commmunications>Protocals>TCp for communication and to read and write data use variant to flattened string. I have attached a small example where i will transfer a constant string to the host PC to check the link between client and the server. Hope this helps you.
Message 4 of 8
(6,879 Views)
May I just add another question....I have an external data streaming into TCP Server with data length of 1024bytes. I understand that the the conventional way for LabVIEW is to use the two TCP Read VIs to process the incoming TCP data. currently, I have set the 1st TCP Read VI to read 4 bytes first while the 2nd TCP Read VI to read 1024bytes. The VI runs fine but I am unable to see any data received on the chart/indicators on the receiving end.
Please point out my mistake. Thanks.
Message 5 of 8
(6,869 Views)
can you post your code. so i can help you in a better way.
Message 6 of 8
(6,867 Views)
Oops...Blind me...I thought the installer did not come with the examples as I could not locate them in the "NI Example finder"....Cheers for replying....I'll try to see if it is possible
Message 7 of 8
(6,866 Views)
I have attached the file.....
Message 8 of 8
(6,817 Views)
