如何在图形表里显示 y=4x 这条直线?
本人刚学labview,是菜鸟一只,希望各路高手能出手帮帮小弟解决这个难题。
题目要求:出啦上述要求外,x为当前系统时间。谢啦
(2,979 Views)
You will be more likely to get a response if you post in English on the LabVIEW board, or post the question in your language on the foreign language board instead.
(2,964 Views)
His English post is here
(2,956 Views)
Accepted by 林哥
您好,
可以用Programming => Waveform => Build Waveform来生成您需要的曲线。
参数1: t0 is the start time of the waveform. 可以用Programming => Timing => Get Date/Time In Seconds 函数为其赋值(current time).
参数2: dt is the time interval in seconds between data points in the waveform.
参数3: Y  contains the data values of a waveform.
但是您将如何定义y轴的值?是current time in seconds * 4? 还是 elapsed time in seconds *4?
如果y值是前者则问题会比较复杂,因为需要一个基准时间参照来做比较。我贴一个简单例子,希望可以帮上忙。
Regards
MY
(2,939 Views)
