11-04-2008 03:05 AM
我想把采集的数据保存为整分钟文件,即0秒开始,每60秒保存为一个文件,然后顺序创建一个文件,继续保存,文件名包含当前分钟数。
I want to save data as integer minutes, every 60 second,Create a file to save data,and its name including the minute。
I use TDMs, please help me, I am waiting。。。。。
Solved! Go to Solution.
11-04-2008 03:35 AM
HI FAY,
Use this vi i thing this will help u.
11-04-2008 03:45 AM
Hi Santhosh M
sorry, My edition is 8.2 , so could you please save it as 8.2 edition?
thank you very much
11-04-2008 03:50 AM
Use this VI for 8.2
11-04-2008 03:53 AM
Nisar converted that vi to 8.2 pls refer that, thanks to Nisar
11-04-2008 03:55 AM
Hi Nisar F
the annex of your is still 8.5, I can not open it
thank you very much
could you change it?
11-04-2008 03:57 AM
hi
use this vi
11-04-2008 04:09 AM
hi, Santhosh M
it seems that the vi can not run correctly.
and I want save data continuously, and save one minutes data into one document.
I do not know whether you undersant me.
11-04-2008 04:38 AM
11-04-2008 05:12 AM
hi Santhosh M
thank you very much.\
it works. but
it only save one document, not continuously, _1,_2,_3.......
So could you please try again?
