怎么让程序安装到其他电脑时,自适应分辨率,不变形
我在我的15寸电脑上写了一个程序,铺满了15寸的电脑屏幕,生成安装程序之后,在14寸的电脑安装运行,发现面板上的图形都跑到屏幕外边了,有没有办法让他自适应分辨率。VI属性我已经调过,没有解决
(3,752 Views)
you should create a frontpanel with smallest display resolution in mind.
It's far easier to display a smaller frontpanel on a bigger screen than the other way around!
(You might set the frontpanel to maximized and enable scrollbars - I would consider such an UI as "ugly".)
(3,742 Views)
因为要显示的东西很多,不太好做更小的
(3,731 Views)
Accepted by 熊熊
Hi raging,
Because to show a lot of things, not too good to do smaller
Well, there is no other option: develop your frontpanel to fit on this 14inch display!
(You might use tab controls to separate important data from less important and show them on several tabs. You might use subpanels with the same purpose. You might use scrollable tables/listboxes.)
Please post in English as this is the English speaking LabVIEW board…
(Use GoogleTranslate as I do!)
(3,727 Views)
