Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
1/0 Signal Generator
damian 30
Member
07-10-2003
06:06 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
Does somebody know if there is a 1/0 signal generator in Labview 5.1 where I can specify the length of the durtion of 1(true) respectively 0(false)?
0
Kudos
Message
1
of 2
(2,608 Views)
Reply
Re: 1/0 Signal Generator
Oleg
Active Participant
07-10-2003
06:21 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
if I understand you right you can use "Pulse pattern.vi" or "square wave.vi" from "functions->analyze->signal processing->signal generation" palette. Set the value of amplitude to 1 and you will get what you want.
Good luck.
Oleg Chutko.
0
Kudos
Message
2
of 2
(2,608 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
