1-D Waveform Array analysis
High all, I have a voltage waveform that I would like to analyze for a pass fail test. It is a discharge waveform and I have attached a photo of what it looks like. I would like to find the amount of time it takes to discharge to 10v from the max voltage. Any ideas of how I should do this? I am not that experienced with working with arrays in labview.
I have attached the vi i am using to measure the waveform as well.
Thanks!
(4,503 Views)
Accepted by topic author KovAcevich7
You can try using a for loop. Right click on the for loop and you can make it "conditional" which means you can stop it based on a condition.
For the condition I would do something like (previous value > 10) AND (current value < 10). You can get the previous value by using a shift register.
(4,478 Views)
In order to find the index of that array element, would you use the loop interation counter?
(4,459 Views)
Yep
(4,437 Views)
@crossrulz wrote:
Yep
Kind of:
The vi pulls out the dt and y components, searches for the max and then looks for the index where the curve passes through threshold and calculates the discharge duration.  The negates are there because threshold array only looks for rising edges.
(4,429 Views)
