how do I highlight text control text programmatically?
I have an application where I'm passing a string of text to a vi string control.  When the vi opens, it is written such that, programmatically, it gives the text control focus, which is working.  The control does have a border around it and it does take text from the keyboard.  The problem is, I want the text to be highlighted, so the user can replace the displayed text with the new text w/o manually deleting what is there... or the user may choose to keep the existing text.  How do I highlight the text programmatically?
Thanks.
(5,616 Views)
Hi rickford66,
you can use the selection "start" and "end" property.
Mike
(5,611 Views)
BTW, I am using LV 7.0.  Does 7.0 have start and end properties, I can't find them.
Thanks.
(5,607 Views)
Nevermind, I found them.  haha
Thanks.
(5,606 Views)
Using LabVIEW 2013, I have to set the control's KeyFocus property TRUE before setting the Numeric Text: Selection property.  This may be application specific because I'm setting the control's text selection on a Mouse Up filter event, but the cursor may not already be in the corresponding control.
-Steve K
(4,834 Views)
