10 port valve control
That is how we use those valves too.  The best way is to create your task for sample on demand, then write a program that has a user defineable timer in it that generates a one time true pulse that lasts 100ms then remains false for the rest of the user defined interval.
Message 31 of 36
(1,484 Views)
Fbaird, thank you for the advice. I'll try to implement what you said. Answering your question, the process I'm working on requires that the valve changes its position from time to time, for example, the valve needs to go from one position to the next after one hour in a continuously way. I tought that with labview I could create a system able to control automatically these changes, using the daq assistante for example
Message 32 of 36
(1,483 Views)
Thank you Fbaird. I just started to use labview, so I have a lot of doubts. With time and a lot of reading I think I'll be able to implement what I desire. But you already gave me a direction.
Message 33 of 36
(1,478 Views)
Do you have any VI as an example? I'm having some difficulties to assemble all the functions you mentioned.
Message 34 of 36
(1,470 Views)
Since you are just getting started I have attached a universal timer code that I would use for such an application.  I have also attached a quick and dirty example for you of what you might want to do.
Message 35 of 36
(1,467 Views)
Thank you Fbaird. A have a later labview version (2012). I'll have to convert the VI's.
Message 36 of 36
(1,458 Views)
