100% cpu time on application but not vi
I am trying to build an application but I am running into a problem i have not seen before. I have a vi that uses 3 while loops simultaneously. It works fine when i run it on my developing machine as a vi, but as soon as i make it an application my cpu usage goes to 100%. It still functions, but obviously the pc is doing to much work. Any ideas on why this is happening? Labview 7.0
(3,365 Views)
Do you have "Wait until ms multiple" in your loops or not?
If you don't, put them in, even if you wire a "1" to the terminal. This will free up the OS scheduler to prevent 100% CPU utilisation.
Hope this helps
Shane
Using LV 6.1 and 8.2.1 on W2k (SP4) and WXP (SP2)
(3,355 Views)
There was a post regarding something along these lines yesterday, and one of the reasons that that might be happening, is because when you're developing and you run a vi, it's the LabVIEW engine that's taking care of it, but when it's an exe, it's the operating system. I don't know too much about this stuff, but maybe that'll point you in the right direction...
I'm sorry I couldn't find the posting from yesterday (lousy work is getting in the way!)
Geoff
(3,352 Views)
If possible, place your VIs here, and our enthusiasts here will be able to help you 🙂
Cheers!
Ian F
Since LabVIEW 5.1... 7.1.1... 2009, 2010, 2014
依恩与LabVIEW
LVVILIB.blogspot.com
(3,351 Views)
I have at least 10ms waits on each loop. It is odd also, because i have created many appliations in the past and the cpu time has never been different compared with the .vi. I even tried the lowest priority and the app still uses 100%.
(3,348 Views)
Post a picture of your block diagram and we'll have it sorted in a jiffy 😛
I hope.
Shane
(3,342 Views)
Well i dont really understand but i got it to work now. I installed the lastest visa runtime engine ( i am using the serial vi's) and now it works fine as an application. Go figure...
thanks for all the help!
(3,325 Views)
