Waterman,
@Watermann wrote:
hi Uwe,
sorry, but I found nothing relating to this error number.
how is the behaviour when increasing the loop delay?
is it possible to test the application with MS Word 2003?
greets!
At this time I have a delay of 250 ms inside the loop and it works most of the time when adding text strings only. It breaks however when I attempt to add a graph into the report and than have the loop with other text strings following quickly. In execution highlighting mode it works reliably.
Ähm, maybe I could try getting a Word2003 license. But I'd prefer avoiding the hazzle of upgrading just for a try.
I was a technical author for several projects and with several version of MS Word. My impression was that there have been just a very few bugs that had been fixed with newer versions. Almost ever they introduced new features with new bugs instead.
So if you have a good reason that this would help, I'd try it.
Thanx for your reply!
Greetings from Germany!
Uwe
