-107418650 error with PXI-4070 even W/O autorange.
Wanted to work on a different project and after installing the newest versions of the drivers this is what I have.
I'm not positive it's Kanji but it doesn't seem to be English. Uninstalled and reinstalled the drivers with the same results.
Message 11 of 15
(961 Views)
NI-DMM 3.0.4 includes the following bug fixes:
  • Fix related to code not generating in the Japanese versions of LabVIEW when the NI-DMM/Switch Express VI was used with switch devices (ID 276993).
Guess they fixed it too wellSmiley Very HappySmiley Surprised
Message 12 of 15
(946 Views)
This morning I uninstalled everything dealing with LabView and installed 2011 from the DVD's. Cleared up the problem with the text but I still have the memory error problem.
Message 13 of 15
(942 Views)
Accepted by topic author Tom_from_the_Lab
Tom,
I am glad that you were able to get the language back to English.  As for the memory error, I was able to run your test during the night and after about 700 iterations, I received the same error that you did.  I then ran it again and got that error after about 500 iterations.  Because this seems to be an issue on our end, I will be filing a CAR (Corrective Action Request) on this issue, for R&D to take a look at.  Thank you for bringing this issue to our attention, and I will let you know what the CAR number is, as soon as I know.
Brian P.
Applications Engineer
Message 14 of 15
(934 Views)
Hi Brian,
Glad to see it wasn't some error on my end that I kept overlooking.
Message 15 of 15
(923 Views)
