10nA current source
Hello all
i would like to generate 10 nA current source  through NI PXI card.  Is there any PXI card that give me the precision current source upto 10 nA. If 10 nA is not possible then what is the minimum current that can be generated using PXI card.
keyur Makadia
Sr. Application Engineer
Optimized Solutions Pvt. Ltd.
(3,529 Views)
PXI-4130 Smiley Happy
10nA resolution on 200µA current programming range
Also take a look at the Keithley 238 High Current Source-Measure Unit, 100fA step size at lowest current source range Smiley Surprised
(3,518 Views)
