prony's method help needed
Dear all:
I just started to use pron.vi. I need to decompose a signal for amplitude, pahse and  damping. If I connect my signal,I am not getting anything.
Even there is no example to practice in the labview help file. Could any one pls give an example /solve problem that used prony's method. I am confused to use it/
Thanks in advance.
AK
Moin
Message 1 of 8
(5,644 Views)
What is that pron.vi? Smiley Indifferent
Example will be available in the NI Example Finder in LV's last menu item. Smiley Happy
- Partha ( CLD until Oct 2027 🙂 )
Message 2 of 8
(5,627 Views)
sorry for the typing mistake. it  would be prony.vi as i mentioned in the subject head line.
thanks
Moin
Message 3 of 8
(5,610 Views)
Ok... but still I m not clear about it. Smiley Indifferent
Does it perform some kind of comples mathematics? Did it come by installing any LV toolkit?
Can you post a snapshot of its Context Help?
Message 4 of 8
(5,606 Views)
Pls see the attachement.
Moin
Message 5 of 8
(5,602 Views)
Would you please post a data sample and the VI about how you call the prony VI?
Message 6 of 8
(5,595 Views)
Thanks for your prompt reply.  are asking for sending the prony.vi or the data sample that i am trying to fit. pls inform me.
thanks
Moin
Message 7 of 8
(5,589 Views)
Please provide the data you want to fit.  And I can provide an example for you.
Nanxiong
Message 8 of 8
(5,558 Views)
