1502 error previous solutions not working
1502 error when trying to build exe. Previous versions of this code built succesfully. Tried various solutions found after search but none work. Application builder errors on "set current font.vi" Cannot build exe with debugging enabled - exe has broken arrow. When I de-select "Remove unused members of project libraries" and build LV acts "lost" and cannot find DSC controls even after I point to the correct libraries (???). Thanks in advance.
PaulG.
Retired
(6,323 Views)
Accepted by PaulG.
Under "Additional Exclusions," try unchecking Disconnect type definitions and Remove unused members of project libraries.  Let me know if this helps.
(6,280 Views)
Your solution worked. I had tried this previously but when the compiler was processing it acted like it was "lost" and "blind" looking for my DSC module controls (2D, 3D valves, pumps, etc.) and I thought it was pointless. However, this morning I tried it again and this time I had to point LV to each.and.every.DSC.control. About a couple of dozen mouse clicks later I had a successful build. Thanks. Smiley Happy
PaulG.
Retired
(6,243 Views)
I found that I only needed to uncheck "Modify project library file after removing unused members"
(6,175 Views)
For anyone unexpectedly stumbling upon this problem: pjackson59's suggestion worked for me (LV 2011).
Thank you to all contributors for the valuable help.
Paolo
(4,602 Views)
