1530 output
The 1530 only has a 4mA current source but many accelerometers need a constant current excitation of 2 to 20 mA. Will the 1530 provide enough power? If not, how can i provide that power?
Thanks in advance
-Jake
(3,017 Views)
Can you be more specific ?
The 1530 current source, is an analog output?
Which accelometer?
Is the 2 to 20mA, an analog input?
(3,009 Views)
Hi J-Car,
Unfortunately, as you mentioned, the 1530 only outputs a maximum current of 4mA and may not work with your type of accelerometer. Could you be more specific as to which accelerometer you are using and who makes them?
S_Hong
S_Hong
(2,983 Views)
