How do I process realtime images to generate a control signal
Hi, hopefully someone can help get me started on this problem...
My ultimate goal is to be able to:
1.  Capture an image
2.  Process it to locate the position and orientation of an object within the image (I am using 2 different size circles drawn on the object which should be easy to locate.  The center of the large circle is the center of the object.  Drawing a line through the centers of the two objects gives the orientation)
3.  Determine the error from this data to a required final position and orientation
4.  Output a callibrated control signal to manipute the object one step closer to the desired position and orientation
5.  Repeat steps 1-4 until I get to the final position and orientation
Sounds simple.
But I am new to Labview and NI Vision assistant, and haven't yet been able to integrate the two.  Does anyone have an example Labview vi that would create a loop that captures an image, processes it in some fashion to extract some positional data, outputs a control signal and repeats the loop until the user stops it.  If I can use this as a model, hopefully I can figure out the finer details.
(Note: for test purposes I am using a USB camera, with drivers that are allowing me to capture images in Vision Assistant for processing.)
Any information that can be thown my way would be appreciated!
Neil
(2,744 Views)
Use the initialize command and cloase command outside the while loop.For the acquire u need to define a buffer do that but place the imaq create out side the loop.Now if u have connected the camera properly u should be able to continously acquire the image.If u need further details let me know the camera u r using.
Now for the next part of your programming u can do 2 simple things.One is to go with pattern matching where u need to define the template and most importantly the the output will give u a cluster specifying the orientation.U can use it for further processign or u can use a co-ordinate system which is similar to pattern matching.Start acquiring images first the rest is pretty easy.
(2,694 Views)
Muks,
Thanks for the quick reply.  Your advice was helpful.  I was able to enumerate the two cameras that I have, and can select between them with the image aquired within the loop.  Works well.
Over the coming days, I will work on the image processing to see if I can extract the positional information.
Neil
(2,667 Views)
