16bit image not correctly displayed by IMAQ Vision (IMAQ ArrayToImage.vi)
Dear developpers,
I'm trying to draw interactively and retrieve a Region of Interest in an image by using IMAQ Vision.
Before doing the ROI, I need to display the Image.
I have an array which comes from a camera, it's an array of 16bit data.
When I convert this array to an image by using "IMAQ ArrayToImage.vi".
The image is displayed but not correctly.
I tried to convert the array into a 16 or 8 bit array but without success.
Could you help me please?
(3,762 Views)
Are you using the 16 bit palette?
George Zou
(3,724 Views)
Yep, George nailed it.  Right-click your 16-bit display on the Front Panel, choose Palette from the Drop-down, then choose GreyScale.  Note that you get a rotated (do you know why?) version of your Intensity Graph.
Bob Schor
(3,709 Views)
Yes, I use a 16bit palette
(3,676 Views)
Accepted by topic author MAILFERTSeb
The solution comes from the "16-bit display mapping" option: right-click on the image.
I don't know why the image is rotated...
(3,670 Views)
The image is rotated because IMAQ displays a 2D array differently from an intensity graph. For IMAQ rows are displayed horizontally and the origin (X=0,Y=0) is top-left. The intensity graph displays rows vertically and the origin is bottom-left.
(3,660 Views)
By default. Right click it and set "transpose" (or transpose array) and it will rotate the data for you.
Than it might still be flipped, but typing a 0 in the max of the scale will flip the scale (or use the flipped property of the scale).
(3,635 Views)
