Failed to load shared library nilvdmt.* in myRIO 1900
Hi eveyone,
I'm working on a simple communication chain, in which I use the modulation Toolkit, with ASK modulator and Demodulator I works well when I test it in my computer but when I try to run it with the myRIO I have the next error message:
Deploying niDMT.lvlib:mod_Remove Coarse Frequency Offset.viniDMT.lvlib:mod_Remove Coarse Frequency Offset.vi loaded with errors on the target and was closed.
Please take a look at the attached image.
I found this problem is in the demodulator side.
I tried to solvi it reinstalling all software in the myRIO card but it doesn't works.
Anyone knows how to solve this problem? I have been working on it for a long time
Thanks in advance
Kevin
(2,689 Views)
Hello niamhw,
Could you please give me more deailed description of your project. What kinde of modules you are use and the configurations on LV.
__________________________________________
The best way to thank, is to give KUDOS
(2,625 Views)
Hello Kevin,
Do we have any update on here?
(2,603 Views)
