1D Array Threshold Value Search
I have a 1D array of data. I would like to search the array for the first time it exceeds a threshold value.
I have tried using the "Threshold 1D Array" VI but not getting the results. It looks like that VI searches for 2 consecutive values, which occurs much later in my array.
How can I search for the first occurance of a singl point that excedds a threshold I set?
(4,002 Views)
You could use "Greater?" to see when your array exceeds the threshold. Then use "Search 1D Array" to get the index of the first value which crosses the threshold, like this:
Threshold
(3,988 Views)
I am following you for th most part, but how / where do I connect my array data?
(3,980 Views)
Accepted by CastleWorks
You would replace the for loop with your data, so instead of the for loop you would have something like:
(3,977 Views)
