1D threshold giving me zero
I am trying to use the 1D Threshold to give me the x index of the y values in order to find the time constant; however, the 1D Threshold is giving me zero when there clearly is that value in the data. Anyone know why it is doing that?
Thank you
(3,310 Views)
Accepted by TylerHoot13
Read the documentation.  Threshold 1D Array expects a constantly increasing array.  And since your first point in the array is larger than your given threshold, it says that 0 is the first point that exceeds your threshold.
You could reverse the array and then subtract the result from the number of points in the array to get your desired index.
(3,300 Views)
