1d array transpose
Currently i am working in labview. i want to traspose my row of 1D array into column. Can anyone tell me how to transpose 1D String array in labview. i Tried Transpose 2D array in labview 6i. It is not allowing me to connect string as the input array. It is expecting me to give Numeric Array.
thanks,
kalpana
(6,692 Views)
In LabVIEW, there is only a visual difference between an array displayed as a row or column. You just change it on the front panel.
(6,671 Views)
If you need to combine it with some other arrays, you can transpose after you combine them. I believe if you use the "Build Array" with two 1D arrays, then you will get a 2D array with 2 rows and N columns (N is the length of the longer array). At that point you could transpose it to get 2 columns (often useful for writing to reports). If you right click on "Build Array" you can choose "concatenate inputs" which would result in a 1D array containing N+M elements, where N and M are the length of the two arrays you concatenate.
(6,632 Views)
If you want to add the 1D array as the last row of a 2D array, it is easy, just use the build array function like I said. If you want to add the 1D array as the last column, it's a bit trickier. You will have to transpose the 2D array, build the array, then transpose the 2D array back again.
(6,627 Views)
Hi kalpana,
here you find the "Transpose 1D array" function you are looking for!
(6,607 Views)
