2 VIs open when I double-click main.vi in project manager
When I open my main.vi from project manager another vi opens up with it. Not really a problem but a little strange and annoying. LV2011.
PaulG.
LabVIEW versions 5.0 - 2023
“All programmers are optimists”
― Frederick P. Brooks Jr.
(2,562 Views)
Accepted by PaulG.
If it is always the same VI that opens, that VI is probably set to open its front panel when loaded.  Look in VI Properties->Window Appearance->Customize.  Right-hand Left-hand side, bottom checkbox.
(2,554 Views)
Of course. Don't remember setting it, though. Smiley Happy
PaulG.
(2,524 Views)
If you ever setup the VI as a top level application window in the Appearance settings, that would have checked the option.  If you went from that to customize, you would have had to manually uncheck it.
(2,515 Views)
That's what happened. This vi is a top-level from another application.
PaulG.
(2,511 Views)
