2 buttons
Hi experts,
i have a small problem with a part of my program. So i have 2 buttons. If button 1 is switched to logical "1" then button 2 should be switched to logical "0" and button 1 stays "1". If button 2 is switched to logical "1" then button 1 should be switched to logical "0" and button 2 stays "1".
I tried to write a program for it but it doesn't work perfectly. I added it as an attachment.
Thank u for your help,
Message 1 of 10
(5,447 Views)
Use a case structure and inside case corresponding to button 1 use a invoke node for button 2 and re-initialize to default. Do the same for the case corresponding to button 2.
Message 2 of 10
(5,445 Views)
Message 3 of 10
(5,441 Views)
I get it differently now. Try this
Message 4 of 10
(5,438 Views)
Use a radio button and you won't have to write anything.
Jim
Message 5 of 10
(5,413 Views)
Yes........:smileyhappy:
Message 6 of 10
(5,408 Views)
Accepted by rrrrtomi
Here is a way using booleans, and using radio buttons.  They behave slightly differently.  If you click on the boolean that is true, it switches values (which is probably undesirable) whereas hte radio button doesn't do anything.  This can be coded for in any number of ways.
Message Edited by elset191 on 11-04-2009 09:01 AM
Tim Elsey
Certified LabVIEW Architect
Message 7 of 10
(5,378 Views)
Well, here is the simplest code around I came up with.  Another one involved using Disabled property nodes.  The way i'm posting is better because you get feedback that you clicked the button.
Message Edited by elset191 on 11-04-2009 09:15 AM
Tim Elsey
Message 8 of 10
(5,370 Views)
Hello Tim,
that is exactly what i need. Thank u very very much!
have a nice evening,
tom
Message 9 of 10
(5,353 Views)
Although I coded up what you had asked for, I still suggest using Radio buttons instead.  There is no code needed for these.
Tim Elsey
Message 10 of 10
(5,349 Views)
