well I think this will work with waveforms and just data points. As for my own, I don't use waveform.
As I have allready mentioned above, you can write your measured data to one dimension of a 2D array and to the second dimension the input position.
The graph should display both in the same window. Maybe you to scale it properly for display.
But take a look at the VI attached to this post.
Stephan
