2 tables in standard report
how do I insert two tables of different dimensions side by side in standard report..........
I am using Labview 2011
please help.............
thank you in advance...............
(2,654 Views)
You don't say what you mean by a "Standard Report".  If you want to use the Report Generator to make an Excel file with two tables, look up a post I made here in January called Revised "Generate Excel Report" Example.  Note that the quotes actually are part of the title -- if you use the Search feature, you should see this pop up when you type the word Revised and then type a space.
If this is not what you are looking for, give us further details.
(2,592 Views)
