2009 3D Graph - Change Colormap!?
Hello All,
 How do you change the colormap on the new 2009 3D Graph Control!!?? It lets you input a color matrix, but no map. Red->Black isn't enough... Anyone?
 Justin Reina
justinmreina@gmail.com
(5,584 Views)
Accepted by topic author Justin_Reina
Hi Justin,
for a 3D Scatter Plot I can create a property node "ColorRamp", where you can set colors with their indices. It's quite resembling the corresponding area of the properties dialog...
(5,577 Views)
Perfect! I saw that colorRamp, but couldn't figure it out exactly.
Why don't they just call it colormap?...
 Justin
(5,569 Views)
Hi Justin,
"Why don't they just call it colormap?"
Because it's more than that? Smiley Wink
(5,565 Views)
In the old 3d Surface there was an W imput where it could be inserted an weight array to module the color of the surface. Does the 2009 3D grap or 3D surface have a similar imput?
Leo
(5,476 Views)
Hi Leo,
I couldn't locate the old example for what you were wanting, can you post a screenshot?  Also, does this ColorRamp Property not work for you?
(5,445 Views)
Smootastic wrote:
Hi Leo,
I can do better and give you a working example and screen shots.
See this thread for a working example (using th CW 3D graph) where you will find in post #9 I include this image
The use of the custom color ramp is shown in post #11 with a preview of that post here.
Ben
(5,442 Views)
