2011 Application Properties Advanced Page View
I am trying to view all of the options on the Advanced Page of Application Properties.
I have an error when trying to load a compiled VI on to an older PC.
The error suggests that I need to disable the SSE2.
This should be possible within the Advanced Page of Application Properties but there is no option to scroll down to view the setting, or change it, from this dialogue box.
Message 1 of 9
(3,881 Views)
Is it not there at all, or is it cut off? It should look like the attached picture.
Message 2 of 9
(3,870 Views)
Took me a while to sort this one out, however I have now solved it. Might be useful for anyone else who has the same problem.
The last 2 options in the Advanced tab were not visible and there is no way to scroll down.
The solution is to set the screen to full resolution and make sure that the text size is set to small - you can then see all of the advance options.
Message 3 of 9
(3,860 Views)
What build type had this problem? Could you take a screenshot that demonstrates the problem? Do you have DSC or other modules installed?
George M
Message 4 of 9
(3,857 Views)
Find the attached screen shots.
The first shows the original error, indicating that the SSE2 needed to be disabled.
The second shows the view I had of the Application Properties Advanced page. As you can see the SSE2 option is not within the view and there is no way to scroll down. All options can only be viewed when I changed the screen resolution and reduced the text size. I am using windows 7. No modules installed.
Message 5 of 9
(3,834 Views)
Thank you for the images. Did you change the Display options in Control Panel to change the size of the text? If so, what is that setting?
George M
Message 6 of 9
(3,820 Views)
In "Display\Screen Resolution\make text and other items larger or smaller" I set the text size to "small"
Message 7 of 9
(3,817 Views)
What was the setting when you had problems seeing the checkbox?
George M
Message 8 of 9
(3,812 Views)
When I had the problem the text size was set to Medium 125% (default setting in windows 7)
Message 9 of 9
(3,796 Views)
