21 > 21 ?
I'm having a program increment until it reaches or passes a value. I noticed it would increment once too many times. Used Highlight Execution and noticed that my Greater? was outputting true with two 21s. Both are doubles (64-bit precision).
Incrementing by 0.25 leads 21=21, but when incrementing by 0.2, they are not considered equal and it will stop at 21.2.
When incrementing to a height of 0.4 or lower, it will stop at the correct increment, but with a height of 0.6 and onwards and extra increment is always included. It stops correctly with 0.1 and 0.25 increments leaves me very confused.
I attached the VI so y'all can try it out. I'm new to LabVIEW so let me know if there's a more efficient way to do something you see in my VI.
(2,869 Views)
Accepted by topic author MarkJonesATX
Expand your indicators to show 15, 16 decimal places.
I bet you are running into a problem with floating point numbers on computers where a number can not be exactly what you think it is.  A number that is obtained by math on other numbers, may not be exactly equal to what you think.
http://effbot.org/pyfaq/why-are-floating-point-calculations-so-inaccurate.htm
(2,859 Views)
The short version is that any number with a fractional part that isn't exactly some number divided by a power of two can't be represented exactly by a PC.   So 0.25 works (1/4th) as does 0.5, and some that seem strange will work fine like 0.2890625‬ (37/128), but 0.1 and 0.4 and such won't work.
A common workaround is to either consider numbers equal if they are within some tolerance amount (0.000000001 or less, perhaps).  Another common one is to multiply your value by a few powers of 10 and then express it as integers.  So instead of going to 21, go to 21000, and always increment by whole numbers.
(2,840 Views)
Thanks guys! Its working now. Definitely something I need to keep in mind.
(2,831 Views)
