Shared Variable with OPC server
I am using  LabVIEW 2015 , i develop a program with TIA Portal V14  , in the TIA Program i am using a rising forehead memory called ( DC : Boolean ) when transforme this memory in LabVIEW using shared variable ( i only read the status of this memory )  the responding Time of the shared variable on LabVIEW is to low . Please i want your help.
Message 1 of 1
(2,512 Views)
