-2147467259 from Database
I am using SQL server(x86), XP SP3, LV2011 and its 32bit also using UDL file to connect to database.
when manually configuring the UDL file then I am able to access database also test connection succedded. When I use the UDL file in my application to connect to database then it generates the error
-2147467259
any suggestion?
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 1 of 9
(5,124 Views)
What did the message that went with the error code say? Also, did you try Googling the error code (in Hex)?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 2 of 9
(5,108 Views)
Yes I tried googling it. Its says it might possible because of architecture issue(64 or 32 bit). But my PC and all application is of 32 bit.
I have seen this error first time in which I am able to confirugre te UDL file and not able to access my database.
In same PC I am able to access database using UDL but not from my application. Method of calling is correctt
I am attaching my UDL as well as my error code
--Ranjeet
Message 3 of 9
(5,098 Views)
There are a number of errors that return that error code. The text is more revealing. Are you trying to use Windows integrated security (SSPI) in the UDL?
CLA
Message 4 of 9
(5,080 Views)
No I am using SQL mode
--Ranjeet
Message 5 of 9
(5,076 Views)
Accepted by Ranjeet_Singh
This problem is solved.
Creating UDL file again in same PC in which application is running, solved the problem.
--Ranjeet
Message 6 of 9
(5,073 Views)
Ah. So the UDL wasn't correct. Could you post the UDL that worked for you?
Mike...
LabVIEW Champion
Message 7 of 9
(5,054 Views)
I'd wager it was either a hardcoded user/pass or poorly implemented SSPI, judging from the error message.
CLA
Message 8 of 9
(5,049 Views)
The thing people don't appreciate is that a UDL is just a text file and so can't get "corrupted" like a binary file can.
Because it's a text file uou can open a UDL with Notepad and see the connnection string that is was defined. This could be a case of something not being setup right in the file, or perhaps permissions on the file itself were configured incorrectly.
Mike..
LabVIEW Champion
Message 9 of 9
(5,041 Views)
