%22formula waveform%22 phase
Thanks for response, but my problem is a little bit different cause i need to generate waveform using existing phases and amplitudes of harmonics. I started with a for loop which searches up to 20th harmonics for phases and amplitudes, i dont know why the output of Tone Measurements vi cant put values into array, can anyone take a look on it?
Message 11 of 14
(509 Views)
Hello Menomena,
I might have a  older version of Labview could you please send a picture of your vi or if you can convert it into Labview 2011 can you do that and send it.
Regards
Sachindian
Message 12 of 14
(504 Views)
I converted my VI to your version (LV 2011). Thanks for your interest in my case
Message 13 of 14
(499 Views)
Message 14 of 14
(483 Views)
