24 bit 2's complement hex string to number
i get a 24 bit 2's complement hex number in string format from serial port. i want use this hex number in continue in my LabVIEW code. but it doesn't work correctly !!
in example if i receive ffffff it is equal to -1 and if i receive 000001 it is equal to +1 .
anybody has solution for my problem ?
Thanks.
Message 1 of 15
(7,988 Views)
See here.
Message 2 of 15
(7,977 Views)
As JB's link doesn't work for me (right now as NI website seems to have its problems) I attach this snippet:
Message 3 of 15
(7,961 Views)
Thank you friends.
but finally i want a number that can be positive or negative. in fact i need number in DBL format with it's sign.
Message 4 of 15
(7,958 Views)
Hi ajapyy,
an I32 is sufficient here as it also keeps the sign (and your "hex number" doesn't come with fractional digits).
You are free to convert the I32 to DBL later on…
Message 5 of 15
(7,956 Views)
That's a pretty clever sign extension, but a little difficult for me to wrap my brain around. An alternative to let LV do it for you would be to use a 24-bit fixed-point type for the conversion:
Message 6 of 15
(7,926 Views)
Accepted by ajapyy
Hi JLewis,
get the sign bit, multiply it by 2*255 to fill the upper 8 bits of the I32, OR it with the remaining bits of the number…
Message 7 of 15
(7,923 Views)
Very interesting ! This is the first time I see this solution.
Message 8 of 15
(7,888 Views)
Hi All
I am trying to converter 4 bit hex string to number. I know the right results. But I do not know how converte. Please see the attached vi
Please help me.
Message 9 of 15
(7,739 Views)
Hi Hong,
please convert your VI to LV2011. Do you mind to write down some example numbers?
And what is a "4 bit hex string"?
Message 10 of 15
(7,735 Views)
