2D Laser Scanning problem
I made Labview design for the scanning application in raster pattern.
So, VI is intended to design to scan the sample in raster patter in applied voltage range,so if I apply -1 min to +1 max it scans that particular area in the applied voltage range.
I am using mirrors and they are configured to rotate 1degree when I apply 1V.
So, now in place of straight line in scanning I need parabolic curve lines to scan the sample and for that scanning parameter for the X mirrror will be the same, when Y mirror ends one line of scanning, but changes will be made for the Y axis mirror to rotate in a such way so that it can able to scan with the pattern of parabolic curve.
so , if some one can help for the same problem then it would be nice.
(4,401 Views)
You need:
1) A conversion from X to hor.angle nd Y to vert.angle
2) A routine to produce the parabolic curve in XY space.
1) is a matter of hor.angle=tan(X/distance) and vert.angle=tan(Y/distance)
2) is a matter of looping over X and then calculating the Y with Y=a*X^2+b*X + c
All basic maths I think, but you'll have to write it out.
(4,390 Views)
Hi mi,
apply a different mathematical formula.
Use a formula to produce your "parabolic" movement - and not the linear ramp you are using now!
(It seems this is a pure mathematical problem, so I suggest to read a book on math.)
(4,387 Views)
Of course it gets (much) more difficult if the steps on the parabolic curve need to be the same length.
But indeed, math, not LabVIEW...
(4,383 Views)
Wow -- you are trying to get your laser to generate what we called "Smiley"s.  We had a ceiling-mounted Laser/Galvo system facing a curved screen.  Because of the geometry, when the beam wasn't earth-horizontal (and since it was ceiling-mounted, this was essentially "all the time"), the beam's path was parabolic.  We "worked out the math" to correct for this (somewhere I have the equations), then my Doubting Student actually stepped the Laser through known positions, measured them, then wrote a routine to "solve the equations backward", i.e. he mapped "known Laser" to "observed Spot location", then did a backwards interpolation to go from "desired Spot location" to "best estimate of Laser Position".  Our answers largely agreed -- I think we went with his "empirical" solution as it didn't need my assumption of a "perfect cylinder" (ours was made of cloth attached to a curved frame -- I think I took into account the offset between Laser Rotation Axes and the center of the Cylinder, but empirically, it doesn't matter, of course).
(4,353 Views)
Bend the mirror
(4,348 Views)
