2D Picture to Intensity Graph
I have three 2D arrays of U8 representing red, green and blue components of an image. I can easily combine them into one 2D U32 array using "RGB to Color.vi" and display it as a picture (see attached VI). What I need though is to display the same image not as a picture, but as an intensity graph, with colors matching those of the picture (i.e. true RGB colors). How can I generate the color table for the intensity graph that would allow me to get the same image as a picture indicator using the same 2D U32 array as my data source? Thanks!
(6,209 Views)
Accepted by Cepera
The Z-scale of the intensity graph is 8-bit, so the closest you can come is by converting the picture to 8-bit using Picture to Pixmap.vi and Unflatten Pixmap.vi.
Then you need to set the intensity graph so that it transposes the array (right-click option) and change the y-scale so it increases from the top (type 0 into the top marker and it will flip).
(6,198 Views)
Thanks Darin! I was missing the "8".
(6,188 Views)
