2D array Display - CPU
I have a 1280X1024 array that I would like to display. If I use Pixmap (to use a picture indicator) or Vision Vis (to dispaly an image), it takes about 3ms and uses about 40% of my CPU (I5 4670K). Is there a way to speed this up and not consume so much CPU?
Best,
W.
(3,525 Views)
WG67,
If you attach the VI you want to run faster we can try to take a look at it to see the CPU usage can be lowered or speed can be increased.
In general though the following link has a powerpoint that is a really great resource for optimizing your VI.
https://decibel.ni.com/content/docs/DOC-15425
(3,498 Views)
and many thanks for your answer.
I could post an image of my Vi but it just the Draw Flattened Pixmap VI (and the picture display), which is slow when dealing with alrge arrays.
Best,
W.
(3,485 Views)
