2D general polynomial fit
@paul_a_cardinale wrote:
I wrote this many years ago.  You might find it helpful.
Did you ever implement it in LabVIEW?
Message 11 of 16
(3,210 Views)
Thank you for reply.
I substracted a mean value from Z. You are right that the error is small in the middle but is about 30% at the edges and it seems to me that it should/must be much better.
I'v done also polynomial fitting with your functions.
polinomial fitting work fine for this measured points but sometimes I can not fit easily some measurement.
I thought that griddata can work much better, specially for low N, since I need to send this interpolation point to EEPROM and have good accuracy of my device.
I attach a VI.
If you have more comment you are welcome.
Regards
Sasa
Message 12 of 16
(3,200 Views)
Here it is.  I haven't looked at this in a long time; don't remember if it had any quirks.
Message 13 of 16
(3,184 Views)
hello again, i know its been 5 years from your last post
but i would like to ask you about the  3DPolyFiArrayOutput VI  how can i adapt it to a 2d array version with random numbers. ( i have changed the dimensions of the array and the intensity graph axis)  but i only get a blank graph ....
here it is my vi with changes..
thanks in advance!Smiley Happy
Message 14 of 16
(2,785 Views)
As a first step, place indicators on all error output. You would immediately see that the general linear fit produces the following error:
Error -20037 occurred at an unidentified location
Possible reason(s):
Analysis: (Hex 0xFFFFB1BB) The number of data points in the Y value array must be greater than the order value.
For a second order 2D fit, you need at least 6 rows of data, so increase N of the outer loop accordingly.
Message 15 of 16
(2,779 Views)
hello again
can you tell me altenbach for this bilinear interpolation subvi which mathematical equation did you use ?
Message 16 of 16
(2,741 Views)
