2D interpolation in Labview 8.5
Hi everyone,
I am  using the 2D interpolation routine in LabView 8.5, with the bicubic mode. Before using that I wrote my own routine to do the bicubic interpolation and I used an algorithm I found on the web. As the results I obtain from the two routines are different, I think that  the weighting functions used in the Labview routine are different from the ones I used. Does someone know the algorithm used to implement the 2D interpolation function in LabView 8.5?
(3,054 Views)
According to the LabVIEW help, LabVIEW uses an algorithm from "Numerical Recipes in C". Chapter 3 is available free online, so try the link and browse to chapter 3.6.
What are you using and how do the results differ? Is the difference significant?
(3,044 Views)
