Building LabVIEW Executables That Prompt For Administrative Rights Under Vista
Hi Everyone,
I've discovered the hard way the differences between Vista and XP...  I've got a compiled LabVIEW program that needs administrative privledges to run.  However, when a user launches the program without proper rights under Vista, it doesn't prompt for administrative rights, it just runs and produces strange errors.  Is there a way to make the program prompt the user for administrative rights so that they don't always have to right-click and select "Run as administrator"?  I heard mention of a "manifest" file that can do this, but I haven't found any details.
Thanks!
Ramirez Kleinigger Consulting, LLC
http://www.thinkrkc.com/
(3,492 Views)
I have no solution, but do you know why have to be an Admin to run your program? Do you write data to c:\program files? or any other 'forbidden' location?
Maybe rewriting your app is the best option?
Ton
My LabVIEW Ideas
(3,483 Views)
Well I suspect there are a couple of things causing the administrator requirement.  I do need to write to Program Files for one important thing.  I need to copy two .NET DLLs from another location to my program's execution path (in Program Files) so that they can be used in my program.  Unless you know a way that I can provide a path to those DLLs, this has to be done.  Those same DLLs may or may not need Administrative rights, I'm not sure yet.  Someone mentioned that maybe if I were accessing the DLLs using COM instead of .NET it might not need Administrative privileges?
(3,478 Views)
Why do you need to copy these .Net dlls?
Aren't they properly installed on the computer?
The GAC (I forgot where that stands for) has a list of all installed .Net interfaces if I'm correct.
Ton
My LabVIEW Ideas
(3,475 Views)
Well I'm not too familiar with this, but it seems they're not listed in the GAC (global assembly cache, I believe).  At least, they're not listed under the assembly list when I add a constructor node to LabVIEW.  Now we've got some similar code using these DLLs in MATLAB via the COM interface like so: h = actxserver('RPI_IOBoard.IOBoard').  That works without any path, so the files must be registered somehow?  I suppose if I went with a COM interface that might remove the requirement for copying files...
(3,471 Views)
