2D string array text wrapping
I would like to know how can we wrap text of just one column in 2D array of strings.
If I try to wrap just one coloumn entire array gets affected. Please see the image to get a better idea.
See how the numbers look, compared to the texts. How can I wrap the text for just the text?
(4,640 Views)
Hi sandy,
can you illustrate, how you want your array to look like after you apply this "wrapping"?
Generic answer: in an array all elements share the same properties, they only differ in value…
(4,628 Views)
I meant that numbers need a smaller width compared to the string.
So I wanted to make it look more elagant like the attached image.
(4,615 Views)
Accepted by sandycoolxyz
hi,
if you just want it to display the data , i would suggest u use the multi colum list box ( Control -> Modern->List,Table and Tree ->Multicolumn Listbox).
best regards
Regards
(4,600 Views)
Use a Table.  Its data type is a 2D Array of strings (which you already have) and you can set the width of each column individually.
(4,516 Views)
