2d Cartesian coordinate rotation
Running lv 8.5, am I misunderstanding how this vi works?  I have entered into the vi the following values
x: 1
y:  -1
theta: pi/2
and the result I'm getting is
x: -1
y:  -1
It seems like it's rotating in the wrong direction!
Additionally see here:
https://www.ni.com/docs/en-US/bundle/labview-api-ref/page/vi-lib/analysis/coordinate-llb/2d-cartesia...
Where the rotation matrix shown is not the same as shown in other sources, such as:
http://en.wikipedia.org/wiki/Rotation_matrix
http://mathworld.wolfram.com/RotationMatrix.html
I find it hard to believe that no one else has experienced this problem so what am I missing?!
(4,896 Views)
Accepted by duerig
You seem to be missing the difference between rotating a point in a fixed coordinate system and rotating the coordinate system.  The sign of the angle is different in the two cases.  This VI does exactly what the name implies, rotating the coordinate system, and the results are exactly what you should expect.  Mathematica, amongst others, assumes that you are rotating a point in a fixed coordinate system, hence the difference.
(4,891 Views)
Thanks for the clarification!  I supposed I can just edit my existing code to work with this by simply taking the negative of the angles before I run them through this VI.
(4,885 Views)
It is working right.
The function rotates the coordinate system about the origin.  It isn't rotating the point about the origin.
A pi/2 is a counter-clockwise rotation of the axes about the origin 90°.  If the point is in the upper right quadrant, +x +y, rotating the axes 90°counter-clockwise will put the point at 1,1 into the lower right quadrant of the new coordinate system +x -y
In the wikipedia example, the points are being rotated in the existing coordinate system.
It is really all a matter of frame of reference.
(4,883 Views)
