2d array - path finder - challeng
I wrote a LabVIEW wire routing algorithm in LabVIEW that is similar (but constrained to only vertical or horizontal lines).  I would recommend an A* algorithm.  They are easy to implement and you can find lots of pseudocode and info with a bit of searching.  I believe I posted at least the priority queue on these forums, but the search is down at the moment, so I can't find it.  If you cannot find it, let me know and I can post it again.
Message 11 of 13
(703 Views)
thanks for your concern I will try to search when the search service is available again
Message 12 of 13
(680 Views)
i don't know which problem you are talking about, but here is the link to the priority queue.
Mike
Message 13 of 13
(677 Views)
