2d matrix matlabscript to labview
Hi all,
I need some small help. I am trying to open a avi file in matlab script in labview and transfer the matrix generated in labview for further processing in labview. I am unable to transfer the data from matlab script to labview.  I attached a picture where i tried to check the matrix size. In both cases i am getting the matrix size. but dont know when i initialise the matrix and try to place the video matrix in an array I keep getting an errorLabVIEW failed to get variable from the script server.
bucnik
bk
(2,659 Views)
Hi bk,
I found a couple of KBs that may help you identify the behavior that you're seeing:
Error 1047 https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019Lk2SAE&l=en-US
Error 1048 https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019NZGSA2&l=en-US
If that doesn't work, can you post the specific error code and description that you see?
Che T.
(2,624 Views)
