2d picture control smooth updates
I have a 2d Picture on my front panel that flickers. I know a solution is to enable smooth updates by right clicking > Advanced > Smooth Updates, but for some reason that option is greyed out. Does anyone know what is going on?
(4,001 Views)
Hi!
What version of LabVIEW are you running and can you drop a 2D picture control in a new VI with no data connected and select Smooth Updates? If you can do it in another VI can you attach your code here so I can take a look and see if we can figure it out?
Rob B
FlexRIO Product Manager
(3,928 Views)
Accepted by SoheylV
Not that much of a solution, but I found the problem. For some reason, if the background of the picture control is transparent, the smooth updates option becomes disabled. I'm using LV 2013.
(3,923 Views)
I found this related thread from way back in 2008.  It sounds like the behavior may have the same cause.  There was a CAR filed for it.
Tim Elsey
Certified LabVIEW Architect
(3,913 Views)
