3 D Array
Hello all,
could someone help me out with this ....it is a three D array constant connected to array size function .The function returns a three element array.I dont understand  this result.
I have [1,3,4] I know 3 is for the row and 4 for the column but the 1 where is it from???? Below is the vi in LV 8.
Thanks all.
ohiofudu.
Certified LabVIEW Architect
Certified TestStand Architect
(3,471 Views)
Hello ohiofudu,
without seeing your vi ( I and most others here only have LV7.1 [or even less]) I would comment this:
you spoke of a 3D-array. This means an array with 3 dimensions thus the array size function gives you 3 values - one for each dimension.
So [1,3,4] is size in x,y,z dimension, whatever this means in your implementation (possibly page, row, column).
(3,464 Views)
I just can double GerdWs post.
But maybe helpful would be the following sentence from LV-help system:
If array is multidimensional, the returned value is a 1D array in which each element is a 32-bit integer representing the number of elements in the corresponding dimension of array.
Thomas
Using LV8.0
Don't be afraid to rate a good answer... 😉
(3,456 Views)
Thanks Gerdws and becktho,
I got it... just forgot my Array fundermentals because of how I wanted to implement my Array........Too munch to think about thesedays....Hmmm!!!!!
Thanks once again!!!!Smiley Indifferent
Ohiofudu.
(3,449 Views)
