Error message: Exception error within external code
Hi
I am getting an error message on running one of my vi's that uses DAQ.mx that causes labview to close it reads:
An exception occurred within the external code called by call library node.  This might have corrupted LabVIEW's memory.  Save any work to a new location and restart LabVIEW.  "VI ......." was stopped at node OX19E4 DAQmx Start Task.vi.
The odd thing is if I put execution highlighting on the vi runs ok and then continues to run OK untill I close Labview and restart it.
Is anybody familiar with this error.
Many Thanks.
Ashley
(3,040 Views)
I've never come across this error before but looks to be a problem with the NI-DAQmx driver. As a first step, I would recommend unisntalling the driver and then re-installing (i would also install the latest version 8.0).
Funny how slowing the code down doesn't present the problem. let me know how you get on with the above.
(3,021 Views)
